I'm sure this is a very simple problem but I'm a bit mystified by the solution.
This morning I decided to change the location of the my documents folder from the C drive which is my new SSD to a partition on my new mechanical hard drive partition F.
During the procedure I was asked if I wanted to move all of my documents but I wanted to leave some folders associated games on the C drive which I did.
Although the documents are moved across they do not seem to have any location assigned to them so if I wanted to move them back I couldn't. Also in the new partition folders are labelled separately and not under a my documents folder. If I click on libraries then documents are there but is no subcategory for my documents, which I wanted to keep but with the new drive location.
I hope I don't seem to confused but I need some help
also the new drive location is showing 100% free space which seems to indicate that the files haven't transferred across correctly ??
