Win 7 trouble shooting
27 Feb 2004
Durham NE England
Wireless will not appear in my network connections
Only local area network shows
If I run the manage wireless networks menu in windows 7 and try to add a wireless connection it days wireless is not enabled.
I have installed a USB wireless adaptor
Add nwu28 wireless but it may not have installed correctly as it shows as a yellow warning sign in device manager
Help/ advice appreciated.
Also if I were to go power line networking which ones are the best to use in extensions? Or on sockets that are also in use by other appliances?
Thanks
Majik
Sounds like at the moment the USB device isn;t working in device manager - you'll need to sort that out first.
If you double click on the device with the yellow warning triangle, what does it say is the problem (could be missing drivers perhaps)?
+1 for getting correct drivers for usb wireless so that it shows as installed properly and then hopefully works :)
Go to makers website and get correct ones for windows 7 32/64 bit depending what you are using
