- 6 Jul 2010
Can anyone tell me how I can get into Safe Mode via the Win 8 installation disk ?
I've tried to follow the link, but in the "Advanced Options" screen, I don't have "Windows Startup Settings". I just have the other 4 options.
http://www.howtogeek.com/107511/how-to-boot-into-safe-mode-on-windows-8-the-easy-way/
Is there anyway to reboot into Safe Mode by entering text via the Command Prompt screen ?
F8 or Shift & f8 don't work.
I can't alter the boot mode in MSCONFIG, because my system locks up after a few seconds after in get to the desktop (Outpost Firewall is causing the lock ups).
So doing it via the installation disk is my only option, but, my options are limited.
I rang Microsoft to ask their advice, but, my call was transferred to India.
So, as you will have guessed, I just wasted 20 mins of time and money and didn't find out the answer.
Thank you.
Thank you.
