** WIN an Akasa Venom Voodoo CPU Cooler **
20 Jul 2009
The bleak North East arm pit of Britain
** WINNER ANNOUNCED **
Hello!
Overclockers UK have teamed up with Akasa for a mini competition to win the brand new and yet to be released (note its on PRE-ORDER HERE) Akasa Venom Voodoo CPU Cooler. ;)
The cooler is designed to fit :
Socket LGA775/LGA1155/LGA1156/LGA1366/LGA2011/AM2/AM3
So make sure you can use it before entering as we have some requirements.
A little about the cooler...
Venom Voodoo, this cooler is definitely rock and roll. Venom Voodoo delivers ultra high performance enabling serious system overclocking. The 12cm killer Viper yellow fan uses S-Flow blades providing 30% more airflow than a standard fan at the same speed. PWM function ensures quiet operation during normal system use and performance cooling under load.
The Black cover and copper heatpipes combined with the Viper yellow elements creates a striking combination which adds pazazz to any system. Six high capacity heatpipes with direct CPU contact provide rapid heat transfer from CPU to high grade aluminium profiled fins. Anti-vibration rubber fan mounting pins provide easy installation and help to eliminate a lot of fan noise. Adjustable mountings ensure full compatibility with all current AMD and Intel CPU’s.
Dual 12cm viper fans giving extreme performance in a push-pull setup where the first fan “pushes” air through the heatsink’s cooling fins, at the same time the second one “pulls” air through from the other side. The combined airflow of two 12cm fans results in more efficient heat dissipation and consequently lower CPU temperatures.
Performance 12cm PWM fan in killer Viper yellow
6 high capacity heatpipes with direct CPU contact
Award winning S-FLOW fan blades provide 30% more airflow
Dual 12cm viper yellow fans
Cooler dimensions 131 (w) x 129.5 (D) x 163.5 (H) mm
To win this fantastic new cooler you need to be able to do the following...
- Take reasonable quality images of the product and of it fitted in your system.
- Test the product and record a few temperatures using software such as REALTEMP for all to see.
- Compare it to your current cooling pruduct even if it is a standard OEM cooler
In order to enter all you need to do is state -
"Im in for testing the Akasa Venom Voodoo"
A winner will then be picked at random the day after the closing date :)
* All submissions will be entered into a random prize draw
* Closing Date For Entries : Wednesday 31st August
* The winner will be announced here shortly after the closing date
* There is no cash alternative for the prize offered
* Competition is only open to UK resident members of the OcUK forum
* One entry per member per address
* Results must be posted by the user by 09/09/2011
** NOTE DO NOT POST EXCEPT TO ENTER AS WE USE RANDOM NUMBER GENERATORS FOR WINNER SELECTIONS **
** ANY MEMBER FOUND TO POST MORE THAN ONCE WILL HAVE THE POST REMOVED TO KEEP THIS TIDY AND ISSUE FREE **
** WINNER **
** POST 207 **
** MEMBER: MARINE IGUANA **
"Im in for testing the Akasa Venom Voodoo". :D
Already have an Akasa Venom so would be good to compare against the original. :)
