win xp home or pro?
Permabanned
26 Nov 2006
guildford, surrey
What does pro have that home dosent? my current computer has home, im thinking about getting pro for my new one when i build it, what are the advantages.
Pro features that aren't in Home Edition
The following features are not present in Windows XP Home Edition.
* Power user Remote Desktop - All versions of Windows XP--including Home Edition--support Remote Assistance, which is an assisted support technology that allows a help desk or system administrator to remotely connect to a client desktop for troubleshooting purposes. But Only Pro supports the new Remote Desktop feature, which is a single-session version of Terminal Services with two obvious uses: Mobile professionals who need to remotely access their corporate desktop, and remote administration of clients on a network. You can access a Windows XP Remote Desktop from any OS that supports a Terminal Services client (such as Windows 98 and, interestingly XP Home). XP Home can act as the client in a Remote Desktop session; only Pro can be the server.
* Multi-processor support - Windows XP Pro supports up to two microprocessors, while Home Edition supports only one.
* Automated System Recovery (ASR) - In a somewhat controversial move, Microsoft has removed the Backup utility from the default Windows XP Home Edition, though it is available as an optional installation if you can find it on the CD-ROM (hint: it's in the /valueadd folder). The reason for this the integration of Microsoft's new Automated System Recovery (ASR) tool into Backup. In Pro, ASR will help recover a system from a catastrophic error, such as one that renders the system unbootable. ASR-enabled backups are triggerable from XP Setup, allowing you to return your system to its previous state, even if the hard drive dies and has to be replaced. Unlike consumer-oriented features such as System Restore, ASR is not automatic: It must manually be enabled from within the Backup utility in Windows XP Pro. In any event, while there is a Backup utility available for Home Edition, you cannot use ASR, even though mentions of this feature still exist in the UI. Confusing? Yes. But it's better than no Backup at all, which was the original plan.
* Dynamic Disk Support - Windows XP Professional (like its Windows 2000 equivalent) supports dynamic disks, but Home Edition does not (instead, HE supports only the standard Simple Disk type). Dynamic disks are not usable with any OS other than Windows 2000 or Windows XP Pro, and they cannot be used on portable computers. Likewise, Home Edition does not include the Logical Disk Manager.
* Fax - Home Edition has no integrated fax functionality out of the box, though it is an option you can install from the XP Home CD.
* Internet Information Services/Personal Web Server - Home Edition does not include the IIS Web server 5.1 software found in Pro.
* Security Encrypting File System - Windows XP Professional supports the Encrypting File System (EFS), which allows you encrypt individual files or folders for local security (EFS is not enabled over a network). EFS-protected files and folders allows users to protect sensitive documents from other users.
* File-level access control - Any user with Administrator privileges can limit access to certain network resources, such as servers, directories, and files, using access control lists. Only Windows XP Professional supports file-level access control, mostly because this feature is typically implemented through Group Policy Objects, which are also not available in Home Edition.
* "C2" certification - Microsoft will attempt to have Windows XP Professional certified with the "C2" security designation, a largely irrelevant status, but one which will not be afforded to Home Edition.
However Home is cheaper and if your not using any of the above why not save money?
It is worth noting that IIS is rubbish.
Remote desktop can be replaced with VNC.
Home supports a dual/quad core processor.
File-level access control is useful for one thing only I don't want to go on a holiday. :p
If it's going to be used for gaming, I would get home or even pro with the vista upgrade coupon as vista will run games 10-20% faster on the same hardware as xp does.
