Win XP Pro Slipstream
8 Jun 2004
Essex
Hi
I've got Win 7 up and running but want to add Win xp to the virtual machine.
I have a win xp pro + SP1 disc. Do I need to slipstream SP 2 to this disk and the slipstream SP3 to to the slipstreamed Win xp pro + SP1 and 2 disc. Hope that makes sense.
I've read that you can skip SP2 if you have SP1a but mine only says "SP1".
Thanks for any help
Cheers
S
Hi
I've tried that but but it didn't work for me. I've ran the prog that chacks that the pc is compatible to virtualisation and mine was ok.
I downloaded Virtual PC 2007 and basically I need to tell this where my xp installation is (as a .ISO) but I want to slipstream the updates first.
I give it a go and see what happens
If you have a Windows XP SP1 disc then you can slipstream SP3 in fine, you can skip SP2.
Slightly off topic, but it's worthing knowing that this is not the case with Vista; you need to install all service packs consecutively.
