Win11 - quick way to change sound output device?
Man of Honour
25 Oct 2002
Hampshire
I switch between headphones and speakers depending on what I'm doing. In Windows 10 you can change this directly from a drop down in the volume icon in the system tray. In Windows 11, it seems ythere is no such option in the systray and you have to open up the sound settings appelet to do this.
Is there some shortcut I can use to quickly switch between output devices under Windows 11?
The option is there, next to the volume slider is an arrow, click that and the list of available outputs is there.
Thanks, I think because it is next to the slider I thought it was an arrow to increase the volume :)
Doesn't seem to default to 100 volume on headphones for me.
