 - 30 Nov 2003
Back story: my neighbours system (purchased from ocuk last december) has been randomly bsod since purchase. The hard drive was replaced 3 times and was thought to have cured the issue but my neighbour is still experiencing frequent bsod mainly when surfing the net
 .....i'm going round this week to check for updates for all drivers and run all the tests: memory hard drive etc but ultimately i think we are going to send the system back under warranty.
My question is that i want to backup my neighbours data using the w7 built-in utility
1. will it back-up ok on a system with bsod issues?
2. how easy is it to use the back-up on the repaired system
3. if the system is replaced i.e mobo will there be issues using the back-up data
4. as per 3 will there be issues using the existing oem w7 ?
thanks for any help on this.
 .....i'm going round this week to check for updates for all drivers and run all the tests: memory hard drive etc but ultimately i think we are going to send the system back under warranty.My question is that i want to backup my neighbours data using the w7 built-in utility
