- 1 Sep 2011
- Peterborough
Hi all,
Currently studying for my CCENT and i have a Cisco 1800 Series router to play with as part of my learning.
Now this would normally connect to my COM port on my laptop. Only thing is, mine is a 15-pin female connection where the console cable i have is a 9-pin male.
Therefore, i have bought a USB->Serial adapter to connect.
Now the problem i have is, when using puTTY, how do i tell it i want to connect via USB using this adapter?.
I hope I've explained that OK. If you need to know anything else, please ask...help!!!
good luck with your studies anyway!
