Deleted member 68110
I'm new to Win8 and wanted some advice.
All my apps display like this (with the column of text to the right half chopped off):-
I'm not sure if this is (really poor and) intentional, to try and draw you into scrolling right, or whether there's a simple fix.
Thanks for any help.
so all websites are badly designed then as they cut stuff of as you scroll down, as do most software.
