win8 help
15 Nov 2011
Oxford
hi bought win8 with 35 gb on my ssd. when i downloaded it it took it down to 11 so it is no longer allowing my to install it :( how come the download took up soo much space?
I assume it's because it creates a copy of your old settings and programs under the windows.old folder which now prevents you from upgrading.
go to the App store, its on the start screen, and it will say if there are any updates needing installed.
Look at top right of screen, click on link for any updates
Look at top right of screen, at click on link for any updates
i click on the app store and it just comes up saying:
your pc isnt connected to the internet. to use the store connect to the internet or try again.
How do you dump that browser choice. I have gone into the updates to uninstall it, and it won't. Then I have gone into C drive, and it won't let me, the reason being, that it keeps popping up everytime I startup.
Don't know if this applies in your case, Windows apps need a minimum screen resolution to work
(Quote)
Metro Apps Require Minimum Resolution Of 1024×768 pixels
A Windows 8 on PC or netbook running smaller screen resolution than 1024×768 pixels, so in such cases everything on windows 8 will work fine but the metro apps may not run or launch
Also have you installed any Antivirus/Firewall Software?
(Quote)
yeh AVG could that be blocking it?
ahh ok just disabled the firewall on AVG n enabled the windows one and it works :)
wonder why avg blocks it
