Winamp - Remove path from m3u playlists
3 Nov 2005
Stoke-on-Trent
Hi Folks
I am using winamp to create a bundle of playlists. The playlist will always be in the same directory as the mp3 file.
By default when I create the playlist in winamp the full path to the .mp3 files is included in the m3u file so if I move the directory the playlist is invalid.
At the moment to get around this I am manually editing the .m3u file and remove the path so only the filenames are listed.
So in esseance I want to use a "local name relative to the M3U file location" rather than the default "absolute pathname"
Is there a setting in winamp to make this behaviour default? rather than me having to manually edit every playlist file.
Thanks
When i used to use winamp i got around this buy whenever i ripped a CD id use a batch file to generate the playlist rather than winamp
Assuming your filenames contain track numbers and sorted correctly you could perhaps do the same
mkm3u.bat:
DIR /B *.m3u > playlist.m3u
Its as simple as that, save the quoted text as mkm3u.bat. whenever you want to make a playlist of the files in the folder copy the bat file in and run it
