winamp toolbar plugin
1 Feb 2006
hi guys,
just wondering is there any such thing as a toolbar plugin for winamp.. by that i mean something similar to windows media player when you hit minimise it gives you a small start/stop, ff, rw, and volume control in the toolbar?
Any ideas?
Thanks
Had a quick look on Winamp.com and found some plugins under the search term of "toolbar". You could also use the Global Hotkeys feature in Winamp. I've downloaded the first plugin on the search results to try that out.
yeah i downloaded another one too which gives a 'track info balloon' in the system tray similar to musikcube.. global hotkeys enabled now and things are going good.. there are some amount of plugins for this software.
Anyone recommend any must haves?
Need a break from writing up coursework here!
