Winamp UI problems.
26 Jan 2005
Hey guys,
Anyone able to help me with this please?
Basically, whenever i load up winamp, the majority of the settings i had before, such as the width of the now playing pane and the media controls pane are reset as well as other things, such as which buttons i want on show etc.
Anyway of making it retain my preferences, i can't find anything in the options.
It's only started doing it since i reinstalled it.
winamp agent? I've never needed this and don't want it anyway and never had an issue with remembering anything in winamp 5 !
Same here, all I thought it did was run the tray icon and helped launch Winamp faster?
Same as both above. I never use it but perhaps it sometimes needs to be used once to permanently set the settings on some systems?
