Windforce 3x graphics card sag
24 Dec 2011
Should a new card be like this?
Some cards just naturally do sag like that. BTW might want to downsize the pic, its a little on the large size to say the least :eek:
Or spoiler tag it, you can get props to support the sagging end of the card. My windows 670 sags I've just dealt with it been In there for 18 months now.
That's not too bad at all. With both my new card and my old 6990 (custom cooled) I had to use cable ties to stop the card snapping up.
Yeah my old windforces sagged. Had 4 in all and they all did. Ninjawire is good or fishing wire to support them. I ended up routing my PCI-e cables from the hole above the card so they held them more upright
:eek: aggghh my eyes!!!!!
Please re-size that OP PIC!!!!!
To support my 7970, I used 2 rubbers from a pencil and an old colouring crayon!
Put that image in a spoiler mate before the Dons see it :)
Image here
As for the card, it looks like it needs a sturdy backplate, not very good from Gigabyte to leave it as is.
Edit> use the PCIe power cables to hold it up, tension them somehow, hide a cable-tie in the cable management side of the case.
Sorry posted using phone as had no system setting up my new system :)
Don't want to use PCIE to support it really so thats out window. I thought about a carbon fiber rod?
Heres another photo of a BETTER photo ;)
Apologies again for eyes
Im sorta dissapointed tbh with it :/
Iv had to modify my parvum to make it fit too >.> the pci bracket is rubbish and didn't align it properly
It looks like your PCIe cables are helping to drag it down.
Id rather make a diy solution.. as said
Carbon fibre rod and add rubber ends to it
Swear someone here did it
Just anything to prop it up, i bit of plastic tubing cut to size, paint it to make it vanish into the background or snazzy it up, put some LEDs on it, do something with it to make it look like it belongs there.
Might might be a good excuse to get creative with it.
