windoes 7
20 Aug 2009
co tyrone
how do you know if windows 7 is 32 bit or 64 bit.
also will 64 bit run on a vista home prumium 32 bit os
thanks for any advice in
It'll tell you on the installation disk ? If it's both versions you will have a choice between x86 and x64 , x86 being the 32bit version. Windows 7 64 bit requires 2 gigabytes of ram and a 1ghz processor to run, so as long as your system has that it should be ok.
