- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
When I use the shutdown option on the start menu windows just goes into a standby mode, and is not shutting down properly. When I select shutdown from the start menu when it "shutdown" it fires back to the login screen for windows.
The only way I can get windows to shut down properly is to run command and use the below command.
Google does not show any real answer for fixing it. Any ideas anybody?
Code:
shutdown /s /t 0
