Squeegee's and Ladders.
Good pointsecondly i wouldn't go with something that sounds like you only clean windows as then you're stuck when you want to promote your other areas.
Howabout
Lees Cleaning
Initial
Clean It UK Group
Thinkofityourself cleaning
first off all good and obvious names will be taken, you'll either need to think of something extra you can add such as UK to the end or something completely new.
secondly i wouldn't go with something that sounds like you only clean windows as then you're stuck when you want to promote your other areas. most window cleaners get into driveway and ovens so sticking a leaflet through the door that says "Hello from cleanwindows, half price driveway cleaning". it sounds like you're just doing it as a small add on and it's not what you're properly doing so wont be as good. perhaps this will be the case but imo you should try to avoid it. anything simple will do even something like Red Tiger, as long as you can get a good graphic designer or design something yourself which looks complete and professional. if you're doing it small time and want to sound personal the best name i'd say is yours. something like Taylor's Cleaning Services, then list the service works good enough.
out of interest how have you chosen to clean the windows and where will you cover?
Window Cleaning Company Ltd
Easy to remember, straight to the point, Easy to work out what you do
