Whist removing plaster earlier i slid the window cill out to get more acces. This loosened the bricks though so a mate is coming to reset them tomorrow.
I also removed the trim around the window as I hope to marmox board around it and then add smaller trim. The window unit it held in by 2 screws into the timber stud each side. Is this normal ? It can move a tiny bit in and out
Left side of window.
I can't really see any easy way to stabilise it? I will fill with expanding foam once I have added sow support for the board edges. I guess once the trim in bonded in place it will strengthen the whole unit ?
Oh and I guess the cill will stabilise the bottom?
