Window Handle Lock
3 Aug 2003
Plymouth, UK
Am having some issues searching for an answer to my issue here.
One of the window handles for a kitchen window has become faulty. When you unlock it to open it, the black plastic part that receives the key and which you press to allow the handle to move falls out. Is only just liveable with as I know it occurs, but could mean that I loose the lock if someone else does it.
Is there a way of fixing this or should I just look at getting a new handle and lock?
I would replace the Handle, take it off and have a look for a makers name and item code, should be easy enough to source a replacement.
