Window P180
14 Feb 2006
Am finally reaching the end of nearly a week of planning new PC..
but have a dilemma over case..
torn between P180 and the Akasa Eclipse....
one thing....are window side panels available for the P180...as I fancy showing off my handywork when finished and maybe with some cathodes etc.....I know that the Eclipse offer the window side panel...
I don't think so... a windowed side-panel would defeat the purpose of the P180. The sides are made of layered plastic and metal to deaden sound, so making a massive whole in it would kinda screw that up :p
I'm sure you could make a window if you really wanted to though! But I would just get the P180 and leave it as is.
Suman
Shifter_Hull said:
p160 with window is great and quiet nice case i own one with side window
I would agree, P160 is also one of the best laid out cases internally that I have used. The sideways-on disk bay is so easy to use.
I must agree I like the P160 but i am sure some company will bring out a side window for the P180 eventually.
I doubt they will due to it being a low noise case, and it already being out for what seems like years :p
