Hey,
I hope I'm posting in the correct forum cause I have a sneaky feeling this might be GPU related but I apologise if not.
I have a quad screen setup run off a single GTX670, 2 x DVI running monitors 1 and 2, HDMI running monitor 3 and a display port to HDMI adaptor running a 4th screen which is my TV in the front room.
Screen 1 and 4 are a clone of each other, monitors 2 and 3 are extended.
So basically I have a standard extended triple monitor setup in my office but my main monitor (no2) is also shown on my TV in the front room when its on.
Anyway, the system runs flawlessly when I leave it and even go into to sleep mode, the windows layout is held in place but I have it set so my monitors turn off after 30 mins just to save power and when I tap the mouse or keyboard after I come back in all the monitors spring to life like they should but I am presented with this;
I have cut out the left and right monitor, its just showing the middle one but as you can see its shifted all of my windows that are usually spread out across the other 2 monitors all neatly on one.
Wonder if someone knows how I might be able to make it remember my window positions after the monitors have turned off and back on?
