- 23 May 2006
Anyone got any experience with upvc windows which can help with this please
I have got old Anglian double glazing fitted at the moment and ive noticed the rubber seal outside has shrunk at either end which I think is the cause of a damp stain on the bottom of the reveal.
Can I just use a universal seal to wedge between the glass and plastic bead?
The seal at the moment is like an E shape that ls welded to the bead, I don't fancy trying to get the bead off incase it breaks. Could I just remove what I can of the E seal and just use a wedge type over the top of it instead?
