Windowed side panel for ATC-110
4 Aug 2003
North Down
Does anyone know if any of the currently available windowed side panels available from Coolermaster will fit the ATC-110? Or if there was ever a panel to fit it. I ask as it is bigger than the standard 201 chassis that most of the upright ATC cases was based on.
Yes you can get them. :)
No idea on what CM has mind. Just be careful who you mention guys due to competitors. :)
The CM 110 panels are larger than the 201, they are unique from the other in that they have two screws across the corner rather than 1 screw in the corner.
I have never seen a ATC 110 window for sale.
The atc 101 has the same size panel. Have a 110 window panel in the loft or garage bought for about £35-£40 a few years back.
The ATC 101 is larger than the ATC 110 - The ATC 100 is the same size, however they were only available in the US.
Yes, the window is very cool, a certain don just posted mine prior to restoration.
Got to post that thread up sometime!
Contact Coolermaster, might take a while, but there is that tiny chance they still have some.
