Windows 10 - 2 problems on fresh system
22 Mar 2017
Poland
My pc:
8700K stock
2x8GB DDR4 GSKILL 3000mhz ( XMP
Corsair 750 i
Asus Z370 Pro Gaming.
I have 2 disks. SSD Crucial 525 GB MX 300 and Toshiba 500GB.
I have an question about system Windows 10.
I installed from Pendrive USB Windows 10 from here:
https://www.microsoft.com/en-us/software-download/windows10
On a fresh formatted ssd i install Windows 10.
When i installed Windows 10 there was a problem with...
1.When i go to windows settings, no matter what i click on system settings it wont opened. SO click and nothing.
2.Problem with web browsers ( Firefox and Chrome ).
When i go to some site, and try to download something ( right click save ), browser just hang,and not respond. I had to click X on the browser.
This happens in BOTH Firefox and Chrome, which is why I think it's an issue on Windows' part?
That was this 2 problems after i installed Windows 10 from Pendrive.
I dont know how but after 2-3 restart now its all fine and working fine.
I just ask why that happened? It maybe was related to my rams?
But i tested memtests and no errors. Thanks for suggestions.
I also checked DISK status, and GOOD HEALTHS.
As above, probably some updates screwing with it or something. Wouldn't worry about it if it's stopped doing it now but if it does it again you might start suspecting a hardware issue.
After 2-3 restart it fixed and working fine. No problems actually in 10 days. So propably software issue or update? I wish no hardware problem?!
I remember only that during this time display driver was installing automically in background by windows.
It's a known bug in Windows 10. I presume you're using Redstone 3. I just had exactly the same thing on a fresh install for a friend a few days ago, I'll see if I can find what I did to fix it
Weird. I am using 1709 build.
I tried for fun to reproduce issue and i made again format and install fresh Win10. But this time all was fine. No problems. But this time i dont had any automatically updates for W10 when on first time yes. Weird.
When i choosed first time in UEFI XMP profile i saved and booted fine to UEFI. I turn off pc,turn on again after 2 hours, and then, i met screen: THE SYSTEM HAS POSTED IN SAFE MODE. This happened just once. Now its booting fine,but i dont know why it booted just once with this message.
Maybe that was related to this or not? Thanks
