Windows 10 and logitech driving force problem
19 May 2004
Put a new skylake system together the other day with a retail windows 10, installed the Logitech profiler thing for the wheel but everytime I restart the pc it shows it as a different wheel and it doesn't work.
Anyone had the same problem or can help?
probably driver thing. i would make sure win 10 is upto date in everything before trying to install the logitech driver for the wheel. it does work but i have had problems before. totally delete any trace of the logitech installer.may leave a cfg if you delete normally.
also usb drivers could be a thing.
if correctly installed the wheel will work.
One of two things.
The mew profiler does not have th edfgt wheel in it, the same as it does not have it for the G27.
Download the previous one for win 8, and it should work.
Or, do below. A lot of people over on thee iracing forums ahve been having issues with logi gear..
For those who run a G27 wheel and got the automatic download from 2016, here is the fix which allows the profiler recognise your G27 wheel and return to normal.
Uninstall the G27 and profiler before completing these steps.
1. Launch lgs510_x64.exe from Logitech drivers.
2. Don't click anything in the driver pop-up but just leave it opened
3. Open C:\Users\YourUserName\AppData\Local\Temp\
4. Do a research with CTRL+F and search for the folder 2b-LGS-x64
5. Open the most recent folder named 2b-LGS-x64 and go to \Common64\Logitech\WMDrivers\
6. Right-click on wmjoyhid.inf and Install. Don't accept the reboot. Close all windows.
7. Close also the driver pop-up and launch again lgs510_x64.exe. Click on next and so on, as usually. This time, the wizard should recognize your G27 as a G27 wheel Smiley Happy
8. After installing, reboot your PC.
And wallah!!
