windows 10 desktop hangs for 1/2 minutes after sleep
12 Feb 2006
Surrey
can anyone suggest what i can do to check why my pc hangs after coming out of sleep mode?
i've very little running and will hang if i leave chrome open with loads of tabs, or with chrome closed. the only apps that are always running are onedrive, google drive, dropbox and f.lux.
i sometimes have chrome open with tabs, sometimes postbox email, but even with them closed and nothing open i still have the issue.
i feel putting to sleep is almost pointless now as the time it takes to fully start up from off to on is the same as the wait i have to get the pc usable after coming out of sleep.
i can start chrome for instance after sleep, but to open a tab and get any thing to happen with a new tab can be 1/2 minutes of waiting, then it all of a sudden works great and everything runs as it should all instant.
anything i can do to check and try improve the speed?
i've 8gb of ram if that makes any difference, and my cpu is some i5 3.4Ghz one.
