Windows 10 PC capping upload speed to 5Mbps
9 Apr 2007
Just got a new pc running and it's limiting my upload speed to 5Mbps, my phone will easily get 30Mbps.
Download speed is unaffected, any ideas what to check?
Latest Lan drivers are installed.
From what you've said so far, first thoughts would be:
How are you connected? WiFi or via Cable?
If via Cable, is it through Powerline or Ethernet all the way to the Modem/Router?
If via Ethernet, have you tried swapping the cable for another one?
Do you have a second NIC on that board?
And do you have another local machine? If so, can you set them up to try and transfer from your new machine to the other one? And vice versa? See if it's limited to the 2.5 NIC. Help narrow it down to see if it's affecting both, or just one.
If only one, what are you connecting to? (Modem/Router in case it can't support it)
And what is the cable in use? 5e? 6? 6a? (Just eliminating all things to not look at and suggest)
Question i have the latest MSI version of the nic driver 10.038, but Realtek have a 10.039 is it safe to use that instead?
No second NIC, im saving files to my NAS at full speed 100+Mbps.
Something i have just noticed, in task manager under network, my computer is constantly uploading something at 5Mbps, how do i find out which program is doing it?
Can't imagine why it shouldn't work and be safe to use. Even if it was incompatible for any reason, so long as you have a local copy of the current driver on hand, it should be a fairly simple matter to restore it or return it to the old one in Windows. If really concerned, make a snapshot to recover to so things are easier to restore to.
Well i have cracked it.
Noticed on my Task Manager graph somthing was permantantly sending 5Mbps. So looked on the Process/Network list and something called cFosSpeed was at the top.
Turns out MSI Dragon Centre had some network lan manager set to on, set it to off and i get my full 32Mbps.
Thanks for the help though always good to have people putting the effort in.
Without MSI Dragon Interfering.
PING ms
13
DOWNLOAD Mbps
142.86
UPLOAD Mbps
30.59
With
PING ms
13
DOWNLOAD Mbps
142.55
UPLOAD Mbps
5.15
Im not sure why it would do it though, whats the point?
