Windows 10 Wifi Connection Problem
12 Dec 2010
Roehampton, London
Hey guys,
Hope I'm posting this in the right section.
I am unable to connect to any WiFi connection. I've tried many adapters, different USB ports (2.0/3.0). I've even tried using the WPS button on my adapter and router.
After entering my WEP key, it gets stuck on Verifying and Connecting. :confused:
I am currently using my laptop's Wifi, through a LAN shared connection.
I am also able to use a Tether from my phone's WiFi connection.
I feel that something went wrong during the installation, as I had to make two attempts, and after many hours of finally getting it to work, many applications are laggy/unresponsive. I am, for example, currently unable to open up the App Store or Settings - they open for about 10-20 seconds and then close. I have a fairly high-end system spec, so that is not the problem.
Any help would be greatly appreciated - thank you.
Thanks for the reply.
It's unable to connect to any wifi connection - even ones without WEP keys.
How would I go about using a static IP?
