- 18 Feb 2007
- London
I literally just started my pc installed latest nvidia driver restarted my pc and now it takes forever to load into windows, signing in from login screen just spins and then eventually a grey screen with mouse cursor. Just a complete slow down!
Just booted into windows recovery and trying the system repair option.
If that does work what’s next best thing to try?
Reset or maybe reinstall of windows?
By the way I changed boot order to usb for the windows recovery media. Does the bios reset the boot priority after, or do I need to change it back in bios?
Thanks
Update decided to try a clean install, not got many files anyway so worth trying, this is second time this has happened though, last time I think I just did a reset of windows, not sure if that entirely the same thing as a fresh install?
Thanks
