I just got a load of new machines into work, which come downgraded to XP. However I want to move forward and use Windows 7. Using the disks that came with the PC I can upgrade to Windows 7 32 bit or 64 bit.
I can't decide which version to move to, part of me thinks that we should go for 64 bit so that we can utilise the hardware more effectively and also move forward in terms of operating systems. However various PCs will need to have old applications running on them which may or not work properly on a 64 bit system. Also, its not just a handful of applications its dozens.
So should I stick with 32 bit or move to 64 and bite the bullet?
