Windows 7 RC1 Build 7100 Problem
27 May 2007
Front of the monitor
Hi all,
I have the above installed on my machine and for some reason sometimes when I start up the machine it wont start properly.. it hang itself before its all started up and I am forced to either log out, which sometimes don't work so have to do a force restart.. But sometimes it can be fine for days without that issue, so a bit strange I think.. also, sometimes when I am doing things like swapping browser or opening another application the screen freezes.. but if I am downloading something it do continue even though I can't see it, I notice that after I have restarted the PC..
Now, would this be sorted with a repair/reinstallation, or should I install another RC1 build that has been leaked and if so, which build would you recommend which in your opinions is the most stable?
I appreciate any and all suggestinos with this little annyoing problem of mine! :)
To rule out a hardware issue I would go for a format and fresh install of any of the available latest builds of Windows 7 (I'm currently using build 7232 x 64, no problems). If after a clean install you still have problems, then use Prime95, memtest86 etc to test for hardware stability and faults.
