windows 8.1 slow and possible virus help
18 Feb 2007
London
Hi
I'm having some problems with windows 8.1, startup is very slow compared to windows 8.
I have run malwarebytes and it found a file called PUP.optional.Alexa.TB.A
I have no idea what this is but I currently have it quarantined.
Should I just delete it now?
also plan on running ccleaner is there anything else I should try.
many thanks
PUP = potentially unwanted program. It might have been bundled with free software.
It probably has something to do with http://www.alexa.com/toolbar
You should have a look at the Start-up tab of Task Manager. It will give you an idea of each programs impact on CPU & HDD during boot.
