Windows based problem?
30 Jul 2004
East Sussex, UK
Good morning guys.
Just a small yet, annoying problem I have recently have had with my system.
The specs are:
AMD A64 3400+ 2.4Ghz
X800XT 256Mb
1GB OCZ 400 DDR memory
300Gb SATA drive
Now I am running Vista Business and all has been just fine. However over the last few weeks, when ever I turn my system off I have two problems with Vista:
If I select sleep or hibinate, the system will just restart and give the screen saying do you want to start windows normally as last shut down was not done right
If I select shut down, it turns off fine. But to get it to turn back on, I have to pull power cord out for 3 secs, then put it back and then turn the system on...: :confused:
Any ideas on this guys?
