I have recently upgraded my motherboard to the Gigabyte GA-8N-SLi Royal and after installing windows running the Nvidia SATA driver, booting fine, all needed drivers installed, updated windows at least 35 critical updates, restarted after installation complete but windows will not boot at all, after the "verify DMI Pool Data" message there is a black screen, if i press F8 to bring up those option, and choose any of them, it goes to which OS i want to start and after hitting enter it freezes. if i try to boot from the Windows CD it freezes on the "Setup up is checking your hardware configuration"
System:
Gigabyte Ga-8N-Sli Royal, Bios Version F5
P4 3.6
DDR2 667 2GB
250 SATAII
ATI x850XT 256mb
and of course Windows XP Home.
Any help would be grately appreciated, its annoying how you can only install or repair windows so many times before it tells you you dome it too many times.
thanks
Lex
System:
P4 3.6
DDR2 667 2GB
250 SATAII
ATI x850XT 256mb
thanks
Lex
