Hi Folks
A few weeks ago I built a new system and done a clean install of XP Pro SP2 x86 and upgraded to SP3, and just recently I've started having a strange problem where Windows suddenly stopped me from being a ble to access the internet.
I'd been using the internet without a hitch for a couple of weeks when two days ago after starting up the system a message balloon popped up in the system tray warning that my network connection had little or no connectivity. I opened up the connection setings and clicked the repair button but it told me it was unable to update the IP address.
I checked all the settings, both software and hardware, uninstalled and re-installed the drivers for the onboard LAN to no affect. I then installed a USB wireless network dongle but got the same results, no connectivity, no IP address. This led me to believe that it is a windows problem and not a hardware/driver problem.
I didn't know what to do, so I of desperation I did a System Restore to a few days previously, which cured the problem.
Then today I was using the internet successfully, put the sytem in stadby and later woke the system back up and was met with the warning balloon in the system tray again warning that I again had little or no connectivity. Again I did a sytem restore and the connection is working again but I have no idea what the cause is and how to fix it.
My internet connection is an ADSL wireless router plugged into my onboard LAN, the router is working fine.
Here is a screenshot:
My system:
Xeon 3110 Wolfdale 3Ghz
Gigabyte EP35-DS3R with Realtek RTL8168/8111 onboard LAN
2Gb OCZ DDR800 RAM
Samsung 500GB SATA HDD
Windows XP Pro SP3 x86
My system:
2Gb OCZ DDR800 RAM
