Windows XP pro showing Half CPU speed
Zaf
Zaf
16 Jan 2003
Derbyshire
I've just installed XP on an old IBM T21 laptop 600MHz but XP is only showing 300Mhz :confused:
Any ideas?
Zaf,
Yes but when you right click on My Computer and goto Properties under the General tab it shows 300Mhz :confused:
personaly i would say your cpu would be running at 600mhz, but windows is not reading the infomation correctly and displaying 300mhz instead of 600, iam sure if your comp was running at 300mhz you would really feel it.. if you get me?
