Windows XP Startup Problem
14 Dec 2003
Glasgow
I am currently having a problem getting my computer to load windows. The system boots up fine and gets to the point where it tells me windows did not start up properly, and lets me choose to start windows normally, last known good configuration, safe mode etc...
Once i have made a selection a white loading bar appears at the bottom then the system restarts. I have tried all options to boot into windows yet i always get the same result.
Before this problem occured i had just installed Nero 7 and Coolbits.
Hopefully someone can point me towards a solution...
Windows XP Pro SP2
Amd Athlon XP 3000
512mb (3x256mb PC 2700) RAM
Geforce FX 5200 128mb
hi there if you installed a copy of nero which was download ;) then most times they contain a virus when you install it, ive lost count the time a virus or trogen was found in nero that i have download from torrents, limewire etc, and if you have i bet you a virus has messed up your boot sector, only way to sort this is fresh install. :D
That sounds about right to me also, I would also suggest someone has eaten some of your ram, i dont know of anywhere that 3*256 = 512 :D
seems like you were spot on ;) . Just done a clean install to fix it, was about time i did this anyway
well 3*256=768, not sure why i said 512, must have been sleepy :rolleyes:
Thanks for the help in resolving this matter
