Running Ubuntu 12.04 64 bit
Wanted to install dotnet20 with winetricks but it won't install on a 64 bit system
so i found this....
Install wine. If you installed 64-bit wine then do export WINEARCH=win32 (as .NET 2 requires 32-bit environment). Then run the command: sh winetricks dotnet20 gdiplus
BUT this didn't work and has now messed up my wine install - any easy way to put things back as they were?
bane2@bane2-EX58-UD5:~$ export WINEARCH=win32
bane2@bane2-EX58-UD5:~$ sh winetricks dotnet20 gdiplus
sh: 0: Can't open winetricks
bane2@bane2-EX58-UD5:~$ winetricks dotnet20 gdiplus
wine cmd.exe /c echo '%ProgramFiles%' returned empty string
THEN WINE STOPPED WORKING I.E.
bane2@bane2-EX58-UD5:~$ winecfg
wine: WINEARCH set to win32 but '/home/bane2/.wine' is a 64-bit installation.
HOPED THIS MIGHT CORRECT THINGS
bane2@bane2-EX58-UD5:~$ export WINEARCH=win64
BUT IT SEEMS IT DIDN'T
p11-kit: couldn't load module: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: /usr/lib/i386-linux-gnu/pkcs11/gnome-keyring-pkcs11.so: cannot open shared object file: No such file or directory
Any help appreciated
thanks
EDIT actually winecfg does open but am still not sure if things are affected behind the scenes so to speak
so i found this....
thanks
