wing bolted or welded on?
20 Jul 2004
Doncaster
My son has bought a mk5 fiesta 1.25 zetec 1999-2000. It needs a new passenger wing just wanting to know wether its bolted or welded on?
thanks.
No...just the 205...although I am going to be stripping the e36 in the next few days...so I may as well take a wing off and come back with an answer. :p
bolted I would have thought. if not it would be easy to split the seam. if the factory welded it up thats a bit stupid, lots of wings get replaced on cars.
Many cars have welded on wings, though it is less common these days.
Pretty sure they are a bolt only job, hope so as I'm thinking of swapping the front wings on mine as both are a bit crumbly around the arches if you look close enough.
Tip for taking off bolted-on wings..Make sure you remove ALL the silly hidden away bolts before you try pulling the wing free! :D
