Wing mirror issues
6 Mar 2008
Stoke area
Hey,
I had the passenger side wing mirror hit while the car was parked about 3 months ago, some of the mirror came off but it was still useable. The other day some idiot in a car couldn't wait for me to get back on to my side of the road and decided to squeeze through hitting my drivers side mirror so hard that the mirror shot out on to the road where it was run over.
Totally unusable I ordered 2 wing mirrors from the wingmirrorman website, £40 for both.
They both look identical to the damaged ones, both heated etc but now I have fit them the electric motors aren't working properly. If the mirrors aren't on it then they work fine :confused:
For instance, if I try to adjust the left only mirror it works fine, if I try to adjust the right mirror it also seems to be adjusting the left. The right mirror also can't more outwards.
Any advice? Things to check?
