- 4 Jun 2010
now its getting colder my cpu is idling in between 15 and 20 is the safe to run or do i need to keep it warmer>?
thanks,
freddie589
thanks,
freddie589
Overclock more
Temps will be fine.
Ah, ok. It's only 200mhz![]()
sorry what do you mean?
im a bit new to overclocking![]()
200mhz increase would not make a huge performance increase, as it was overclocked by Ocuk I would not worry![]()
Dont do it, 200mhz is insignificant amount and you void your warranty.
The current one is probably already called OCUK, mine is.
And saving other profiles should not affect your warranty, updating the BIOS does though.
when you say updating it do you mean downloading and installing a new bios?
Yes!
thanks,
freddie589
Cold cannot harm a CPU, if you see some of the extreme overclock videos, they use liquid nitrogen to cool the CPU to sub-zero temperatures.
