Winter cycling tyres
31 Jan 2009
Newcastle Upon Tyne
So today, I cycled into work as I usually do. Only I hit a few patches of ice and nearly fell off.
I have Schwalbe 2016 Land Cruiser Kevlar Tyres and they are proving to be really amazing. At least for punctures anyway. I have had them since April.
Are they good enough for winter riding or do I need a different set of tyres? Someone at work mentioned softening the tyre by releasing some pressure.
What advice can you give, please?
Thank you! :)
You'll never grip on ice unless you get ridiculous spiked tyres. I wouldn't switch personally.
I use spiked ice tyres and they are brilliant - nothing ridiculous about them at all!
They're quite heavy - close to 1kg per tyre I think - and they drag noticeably more than other tyres but they roll along fine once you get them up to speed.
The grip is amazing. Most of the time I use them incase there are small patched of black ice around but I have had them out in full scottish highland winter conditions with compacted snow/ice 3-4cm thick on the road.
Depends on where you're cycling. They would be ridiculous overkill for me but fair enough - not for everyone everywhere. I should've been more specific.
If you're cycling anywhere that you may encounter ice - as the OP said he did, then it's not overkill.
You only need to fall and wreck 1 pair of shorts to make the cost of the tyres worthwhile.
I encounter ice but for the most part stick to well-gritted roads.
This is exactly the same as me. Most of the roads are well gritted around here and most of the time I wont find any ice at all on a ride. I still consider the tyres worthwhile when the main drawback of using them is losing a few mph off my strava averages whereas the drawback of not using them could be broken bones + broken bike.
Well, each to their own. I don't care about losing average speed (that much :p) but the hassle of swapping over for what I see as a very unlikely event to occur makes it not appeal to me.
