WinTV Ministick Problem
31 May 2006
A friend (not an IT geek) has a new laptop and a Hauppauge WinTV Ministick. It worked great when I installed it. Now they have moved house and it no longer works. It has scanned channels fine (92 odd found) but it wont show any picture. It is running on Windows 7 64bit Home edition. The WinTV stick in question is this one: http://www.hauppauge.co.uk/site/support/support_all.html?prod=24
Of course the Hauppauge support forum is down just when I need it!
I'm going to suggest a driver update but I'm not even certain the ones on Hauppauge's website are newer than the ones on the CD it came with.
Anyone got any suggestions? Does anyone else have this stick? Anything simple to try?
Thanks for the suggestions guys. It turns out that the new channel scan shoved all the refound channels down the end of the list leaving all the old ones at the top. So all is good again!
