Never used a TV card before.. so im having some issues with it.
As you know the instruction manual is more than helpful to say the least
I have connected it up and its it recognised by windows so no driver issues.
I want to connect it to my TV to record live TV rather than connect the ariel to the card.
I am assuming that you plug the scart into the TV and then composite leads into the back of the card.
How do you get Media centre to record the TV.
What other applications can you use to record straight to Divx, avi etc.
Any help or links would be appreciated.
