G18241 said:
can you explain this in laymans terms please lol
Which part is confusing?
- Know and record where the .dll is that you wish to remove.
- Start | Run (type 'cmd' - click 'OK') - brings up command prompt
- Change directory to the one where the .dll is (ie 'cd c:\windows\system32')
- Right click on task bar and choose 'Task Manager', or press Ctrl-Alt-del and choose Task Manager.
- Find explorer.exe in task manager, click on it, then click 'end task' option at the bottom.
This will show your screen being just the background, task manager and command prompt being open.
- Go to the command prompt and type 'del winwim32.dll' and hit Enter.
- Go back to Task Manager, File | Run, and type 'explorer.exe', then click 'OK'
Should fix you up.
Pax
