WinXP network connectivity problem
itm
itm
22 Feb 2011
One of our users is having strange problems with network connectivity which only seems to affect certain protocols (http & ftp from what has been observed so far).
He is on a corporate LAN, running Windows XP SP3. He can do the all of the following successfully:
- access our externally hosted Exchange server using Outlook 2007
- access file servers on the LAN using Windows explorer
- ping external IP addresses
- ping external domain names (e.g. google.com)
He has problems with the following however:
- Accessing intranet sites - sites are found, the page Title displayed and sometimes some or all of the page content, but IE then hangs at 50% CPU usage
- Accessing internet sites - no content is retrieved, and IE hangs at 50% CPU usage
- FTP (from a DOS command prompt) - an error is returned when an OPEN command is attempted on a remote FTP site.
We've run an (AVG) anti-virus scan, but found nothing.
Can anyone suggest what to try next?
No proxy is involved. It's IE version 7. I've just installed Chrome and Firefox and they're both fine. So it's just IE and FTP that are the problem.
Well, IE at least, I'd maybe try filezilla or a proper FTP client to test FTP. At the very least it'll give you slightly more verbose logs than command prompt. But I reckon your main issue is just IE is broken and needs re-installing
