Right just got back from Canada and booted up my laptop, which has been running perfectly fine while i was away. Anyways it booted into windows no problems but it started to hang etc and for some odd reason it was trying to install a bluetooth driver..when i didnt even ask for one to be installed.
Anyways it got stuck so tried to end it via control panel but that didnt work so ended up turning it off. the laptop. Booted it up again and this time it took forever to log in...almost 30 mins before it finally logged into windows and even then it was another 20 mins before all my icons came up on my desktop and the laptop was useable.
So i thought i might as well do a repair job on the winxp installation..so off i went and started the repair job...now usually it doesnt take that long to do a repair job but for some odd reason it took my laptop a couple of hrs to finish it off....anyways managed to get into windows again but its still hanging and taking its time.
Now i could do a fresh install of winxp pro but the problem is that i have quite a few files that i need to backup before i can do so...not a problem or so u think but problem is that now i cannot copy those files over to my external hd...win xp sees the external hd and allows me to open it and access the files but when i want to copy my files from my documents to the ext hd...it wont let me do it...it doesnt give me any error messages or anything. it just sits there and does nothing. Clicking my computer shows the ext hd but before having these problems...the icon for the ext hd was a different one to the one now showing in my computer...
So at the moment im kinda stuck as to what to do really....i need these files backed up...its over 40 gb of files that i need backing up but i cant copy them to my ext hd...
So anyone with any ideas as to what to do??...i cannot afford to lose this data to be honest. Hopefully someone here will be able to tell me if theres a way i can put these files onto my ext hd..
TIA
TIA
. Im using win 2k3 server on the pc i have the hd connected to but like i said i can see the hd no problem but that file, which ill name Spawn..i cant access at all
