WinXP Standard, Basic fonts.
5 Sep 2005
Northern Ireland
Hi guys,
I'm having a bit of a headache with an old WinXP machine that has been pretty much relegated to print server duties (plotter manufacturer never released any Win 7 drivers).
I messed up an accidently deleted a couple of the system fonts, to the point where menus on the machine aren't showing any text. Is there somewhere that you can download a .zip / .rar or whatever of the standard stock XP fonts? I know they're on the Win XP CD, but for the life of me I cannot find the damnable things. :o
Cheers!
they'll be in the i386 folder probably with a .fo_ extension. these are compressed so you need to run the command line utilty expand on them. something like...
Code:
expand d:\i386\*.fo_ c:\test\*.fon
create the test folder first and then copy out just the fonts you need.
Code:
Just getting the error, destination is not a directory, when extracting using the following:
Code:
expand f:\I386\*.fo_ c:\expand\*.fon
I created the c:\expand\ directory to try this, so its definately there. I then tried:
Code:
But that just gives me a bunch of .fo_ files in c:\expand\
Any ideas?
