Wipers for a Mk6 Fiesta
I got the halfords own ones and they're superb I must admit, I had the same problem - the stock ones just smearing water rather than wiping it away, but the new ones are absolutely fine. You don't need the expensive ones, just get their own brand.
Edit: they're not as bad as I thought. I got the halfords ones for about the same price. Probably just as good.
i put some halfords ones on my gf's mk5 fiesta last november. they clear water well but theyre going rusty and look terrible. i have bosch ones on mine, had them since feb 08, no rust at all and still clear water properly. and they were cheaper than the halfords ones
pop down eurocarparts or germanswedishandfrench
Well Bosch do super plus or aerotwins, with the latter being more money. Is it worth paying the extra for? £14inc as opposed to £28ish. Also, whats the difference between a flat and conventional blade?
Might go for standard fit ones for ECP then. Can get all 3 blades for £13.
EDIT: Delivery is loads. Wiperbladesuk it is then.
